ADI HDD and SATA HDD
  • MacTavishLK
    • Nov 2020
    • 70
    Hello,
    What is the difference in ADI HDD and SATA HDD? Why can't we change to SATA HDD from ADI HDD. Please explain Brothers.
    Thank You So Much.
    Have a Nice Day.
  • Rusty.Harris
    • Jan 2021
    • 639
    Re: ADI HDD and SATA HDD
    The ADI or "wipe" drive is a specific HDD that comes standard in every Toshiba TEC copier.
    You cannot replace it with a standard HDD, as these ADI drives are more secure. If you
    attempt to move an ADI drive, to another machine, that also has an ADI drive, the encryption
    keys won't match and all data will be removed from the drive.
    Several years ago, I ordered a non wipe 320 gig Toshiba HDD, then removed the circuit board
    from the wipe drive, and replaced it with the circuit board from the non wipe drive, to see if I could
    access the wipe drive. Apparently they must tinker with the low level formatting of the drive, and
    there is a different chip on the wipe board.
      • 23010
      This is your third post on the same topic. Do you think that if you keep asking, that you'll get a different answer?
      I'm done answering since your not too interested in the replies. =^..^=
      • MacTavishLK
        • Nov 2020
        • 70
        Hello Blackcat,
        Yes. I want to convert Toshiba 256 to SATA HDD from ADI HDD. I attached proffment for that reason. Please look it.
        Thank you.
        Have a Nice Day.
        • Rusty.Harris
          • Jan 2021
          • 639
          Didn't know he had asked this before. Apparently he won't read?
          • Vincent128
            • Sep 2015
            • 350
            You can't.
            Originally posted by MacTavishLK
            Hello Blackcat,
            Thank you.
            Have a Nice Day.
            • MacTavishLK
              • Nov 2020
              • 70
              Originally posted by Vincent128
              You can't.
              Hello Vincent,
              Why are you saying "I cannot"
              I attached some pictures for the proofs.
              Therefore it is possible.
              If you know the procedure please tell me.
              Thank you so much.
              Have a Nice Day.
              • Vincent128
                • Sep 2015
                • 350
                Hello Vincent,
                Thank you so much.
                Have a Nice Day.
                If I gave you some pictures of a pig with wings, would you believe it could fly?
                You are not reading what has been already posted and you are not even reading your own 'proof' .
                You are asking to replace a wipe drive with a non wipe drive..you can't do that in the way you want.
                Your pictures are of a pre-converted non-wipe drive being replaced with a non-wipe SSD - you can do this
                • MacTavishLK
                  • Nov 2020
                  • 70
                  Hey Vincent,
                  Are you crazy man???? I don't want pictures of a pig with wings. That pictures captured from me and I checked those machines. There are working properly. I sure my eyes. It is possible method. If you can search it.
                  Thank you so much.
                  Have a Nice Day.
                  • Vincent128
                    • Sep 2015
                    • 350
                    You still can't read though.
                    WIPE drive to non-WIPE drive = no
                    Your pictures are of a non-WIPE drive to an non-WIPE SSD.
                    AGAIN
                    Your pictures show a Toshiba regular ass off the shelve SATA drive being replaced with a regular ass off the shelve SATA drive which just so happens to be an SSD which is not important and totally do-able, just follow the instruction in the service manual.
                    HOWEVER
                    You are asking to replace a Toshiba ADI WipeDrive with a regular ass off the shelve SATA drive which is NOT feasible. Once those machines were fitted with ADI WipeDrives, there IS NO REVERT function to go back to a regular ass off the shelve drive.
                    THIS is an ADI WipeDrive..your picture IS NOT
                    • prabhath731
                      • Oct 2017
                      • 6
                      AGAIN
                      HOWEVER
                      [ATTACH=CONFIG]50207[/ATTACH]
                      you are wrong some technicine converted adi to sata perfectly our country sri lanka
                      • djbass
                        • May 2008
                        • 168
                        I wouldn't be surprised if there was a hidden 08 code that allowed this, something I wanted to play with back in the day, and by all means, if you know how do share.
                        However the other posters above are not wrong, at least officially there is no known way to revert a machine with an ADI-HDD back to SATA-HDD, the service manual specifically states that you can not.
                        This is in part because Toshiba at the time wanted to position itself in the market as a security-focused company and the e-Bridge 3 devices were a stop-gap to their ADI-HDD only e-Bridge Next platform that came after.
                        No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
                        • IcedHeart
                          • May 2012
                          • 10
                          Returning machines using ADI discs to Normal disc is a feasible operation. I use SDD Disc instead of ADI discs that are in Mif and deteriorated.
