Toshiba fuser parts
  • Rusty.Harris
    • Jan 2021
    • 634
    Toshiba fuser parts
    With the "supply chain" problems, 8508A & 8518A series fuser kits are sometimes hard to come by.
    We we having trouble obtaining the 6LK42666000 FR-KIT-FC556-FU complete kit. We could get the
    fuser belt kit, but couldn't get the entire kit. Well, I had our parts person check, and the separate
    LOWER fuser roller, TABS had 31 of them in stock. So, I stocked up on Fuser belt kits & lower fuser
    rollers. The only difference is the plastic pad that holds the wick.
    So if you can't get the FU kit, just order the fuser belt kit & the lower fuser roller separately.
  • MarkG52
    • Oct 2017
    • 29
    Re: Toshiba fuser parts
    Wish I had seen your post earlier today. I just ordered 4 of said FR kits.
    • Rusty.Harris
      • Jan 2021
      • 634
      They MIGHT be back in stock now. We just received a bunch Thursday.
      • Vincent128
        • Sep 2015
        • 349
        Now if I could just get the belt holder innards assembly ...
        Got a fuser that's dying with broken clips inside...holder is B/O
        • Rusty.Harris
          • Jan 2021
          • 634
          The lady that does our parts ordering said that when she checked Monday morning (15th), it showed parts would be received
          on the 19th (Friday), but she said don't look for them until after the first of December, with next week being a holiday for
          most. Thursday/Friday and part of Wednesday. So shipping at the earliest would be Monday the 29th.
          • MarkG52
            • Oct 2017
            • 29
            Well my FR-556 kits did not arrive today with most of the other stuff that did arrive. Checked Order Inquiry and it shows "Released". But, I've got DSDF rollers on order that have showed "Released" from an order placed back in September.
            • Rusty.Harris
              • Jan 2021
              • 634
              Fuser core
              I love how the "bosses" of Toshiba think. The outer shell of the fuser core (marked in red) is NOT available as a
              part. When I inquired, I was told that the outer shell is "too fragile" to be made available. Ok, then if it is so
              fragile, why are the other parts made available? To get to the thermistors or thermal fuse, you have to take that
              shell off. Oh, wouldn't surprise me they don't make anything in that core available, forcing you to spend $$$ for
              something you don't really need.
              Since using the Shin-Etsu oil, doubling the amount Toshiba says to use, we aren't having as many fuser failures,
              due to the oil drying up (along with cutting the fuser temperature).
              Understanding how the whole IH coil system works, the magnetic lines of flux, creating the eddie currents along
              the entire area, I would think scratches to the surface of the outer shell, could potentially create a "hot spot"
              similar to how a piece of fuzz would create a hot spot, on a corona wire. And, of course they tell you not to
              scratch/scrub the outer shell of the core, for fear of bending/mishaping the core. So, the only course you have
              is to replace an expensive core, or odrering a new fuser from TABS or a repaired one from Hytec. And that's almost
              impossible with "supply chain" issues.
              I almost posted this in the rant section...
              • Vincent128
                • Sep 2015
                • 349
                They defiantly need to relook at this design and do something else....
                I got a machine down that needs a fuser...and it's a print shop..and he is already not happy with us...and we are waaaay in the red with it...
                *sigh*
                Hytec still shows late December
                • Rusty.Harris
                  • Jan 2021
                  • 634
                  Well, so much for that! Our DSM said they had looked into it, and that outer shell is about 90% of the belt holder.
                  Sort of makes sense...if you see what happens when it wears down, it's all copper on the inside.
                  • Vincent128
                    • Sep 2015
                    • 349
                    Well at least is not like the Ricoh 6513's fusers...we had to have the floor stripped and refinished at a print shop once because even though I was careful as shit..leaked fuser oil all along the floor when i was carrying a hot one needing rebuild to the only place in the print shop where there was counter space. Sooo much oil and oil rollers and blades and you couldn't grip your tools for a week after.
                    Engineers man...they need percussive maintenance to the brain pan .
                    • Rusty.Harris
                      • Jan 2021
                      • 634
                      The only GOOD engineers I've seen, are guys that use to be a FIELD TECH.
                      • tnrtt
                        • 156
                        Re: Fuser core
                        [ATTACH=CONFIG]50925[/ATTACH]
                        You wouldn't happen to have a number for that oil, would you?
                        • Rusty.Harris
                          • Jan 2021
                          • 634
                          Re: Fuser core
                          DM-FLUID-200CS
                          Contact Us | Shin-Etsu Silicones
                          I use 2x the amount Toshiba says to use. Never had one come back with a ripped up belt because the oil
                          leaked out or dried up.
                          • tnrtt
                            • 156
                            Re: Fuser core
                            DM-FLUID-200CS
                            Thanks for the info, rusty.
                            • Rusty.Harris
                              • Jan 2021
                              • 634
                              Intermittent thermistors
                              Here's something else we see. When rebuilding the fusers, I always check the continuity of the thermistors. While my meter is
                              checking them (on the wire harness plug...blue wires = center thermistor, black wires = outside thermistor), I put my thumb &
                              forefinger on them to ensure the resistance changes. I'll then flick the thermistors & about 1/4 of the time, they are intermittent.
                              The metal inside is super tiny & breaks.
