Waste box fills up quickly
  • sappa12
    • Sep 2023
    • 55
    Hello...i have few machines e-2505 series wich fills waste box pretty fast...machines dont have that much copies(one has only 100k)
    has anyone dealt with this before
  • Rusty.Harris
    • Jan 2021
    • 628
    Couple things.... that series was notorious for backing up the waste toner bottle, causing the transfer belt cleaner to fill up and the spring auger would pop out.
    Most of the time I found it was sometimes due to the customer running sky shots. Check your toner coverage percentage and if high, that's probably it. Or maybe
    they are running a lot of full coverage images.
    If it is skyshots, one thing I had to do to stop it was to find an old mercury bulb tilt switch, wrapped it on the inside of the ADF, ran the wire down to the plug you'd pull for a
    key counter, and give them a 30-40 degree angle. I didn't tell them I did this and waited for them to call wanting to know why the screen would say "insert key counter" when
    they tried to make copies. NEVER had a problem after that!
    • sappa12
      • Sep 2023
      • 55
      The funny thing is that i have low color enabled on 100k machine and it takes just 10k from last replacement on low coverage to fully fill wast box
      Cant understand that machine slighty pulls toner to waste box without any irregularities on print or copies
      • sappa12
        • Sep 2023
        • 55
        Low color counter*
        As for the tr.belt cleaner...when system report to change waste box,you can put it out shake it and put back in and after that system never again report for waste box full and you get hell marry after some time...once i get that spring auger snaped and one part ripped tr.belt and other scratch all drums. Since then i've been turning 08/4768 (2) function
          • 23003
          Originally posted by Rusty.Harris
          C
          I love that solution! I did something similar on the Kyocera high capacity paper decks. Users would put paper UNDER the lift plate, then when the plate lowered it would snap the cables. I added a normally closed microswitch inline with the doorswitch, then positioned it under the lift plate. When you stack paper under the plate it always shows "Door Open". When they call I would say: "... did you look UNDER the lift plate?"
          Oh, that, yes I remember ...
          You can't fix stupid.
          • Jettdog
            • May 2021
            • 48
            I currently have a Estudio 5516 that destroys the yellow cleaning unit every 6 months. Blows out the plastic seal and destroys the auger spring like you mentioned. I assume the piping from the yellow cleaning unit to the waste toner bottle may be clogged up?
              • 23003
              Likely.
