4505, "noise"
  • Rusty.Harris
    • Jan 2021
    • 623
    4505, "noise"
    Ribon, 4505, page 17, #21
    Ummm...think I found your noise problem.
    Tech said the PLASTIC gear teeth looked fine, but he was waiting until he took the dev drive assembly apart to verify the teeth look ok.
  • mojorolla
    The Wolf
    • 2590
    Sharps DV drives used to do this as well; plastic gears eating a metal shaft. You would think it is not possible, but it is.
    DV material is more abrasive than I first thought.
      • 22999
      Grease on the helical teeth will slow it down, but not prevent it entirely.
      • Rusty.Harris
        • Jan 2021
        • 623
        Tech called me back said all the grease was gray/black and had a feel like pumice. He did find a scattering of powder in and around it.
        Told him to pull a drive off of one in our warehouse and toss that one. I'll betcha the gears are probably a bit "shark fin" looking anyway.
        He pulled one and swapped it. Problem solved.
