E410 on e studio 2505
  • sappa12
    • Sep 2023
    • 57
    Any thoughts on E410....2/3 times a month,swap both front sensor and switch,new power supply...no luck
    Maybe LGC is bad
    • 23009
    E410 is a front cover open during copying jam. There are a few possibilities:
    1) Poorly actuated front door sensor
    2) power supply loss of a voltage
    3) Poor AC power provided to the machine (ground to neutral exceeds 1 vac, hot to neutral varies =/- 10% of rated voltage).
    • Rusty.Harris
      • Jan 2021
      • 634
      Maybe LGC is bad
      Any chance you can put a ESP surge protector on the line, monitor it (including neutral to ground). Download the data and see if
      something shows up.
      • mojorolla
        The Wolf
        • 2627
        Make sure both tabs are present on the waste toner container. Had a few customers attempt to re-use the WTC and the missing tab will pop the front cover open while running, giving E410.
