2508A DOC FEEDER
  • bruce 49dcs
    • Jan 2017
    • 140
    2508A DOC FEEDER
    I can buy a 2508a from wulff but it has a c550 dual scan if error. I have a parts machine with a regular radf can I install that and will it work or maybe an 08 code to tell the machine its a single scan radf
    • 8228
    Re: 2508A DOC FEEDER
    ... assuming you have an MR3031 RADF, no problem. Update the firmware on all to match.
    • bruce 49dcs
      • Jan 2017
      • 140
      yes I have the mr3031 but I dont have the firmware can you maybe help me with that please and thank you
      • Rusty.Harris
        • Jan 2021
        • 634
        Probably need to also set 08-9995 to zero so the machine thinks there isn't a doc feeder, so it will automatically go out
        and look for one, and make all the necessary changes between the DSDF & the RADF. Also, don't forget to remove the
        board for side 2 from the system board.
        • bruce 49dcs
          • Jan 2017
          • 140
          Originally posted by rusty.harris
          probably need to also set 08-9995 to zero so the machine thinks there isn't a doc feeder, so it will automatically go out
          and look for one, and make all the necessary changes between the dsdf & the radf. Also, don't forget to remove the
          good stuff you guys are great thanks much
          • Blizzoo
            • Aug 2013
            • 608
            Install the RADF and go to 05 mode and do 05-3401, this code will set the default adjustment values for RADF wich differs from DSDF. You probably don't need firmware but will be great to have them on same level
