Toshiba e-studio 5005ac jam E580
  • tecnomarco
    • Jul 2011
    • 213
    Hello everyone, I have this TOSHIBA E-STUDIO 5005 photocopier and I have a problem with the front and back... all the sheets get jammed in the reverse section as in the photo... that is, it prints the first side, but when it retracts the sheet to do the back it always gets jammed in the same place as in the photo.... can someone give me a solution... I also dismantled and cleaned the solenoid, eliminating the sticky sponge, but the problem remains the same... thanks to anyone who can give me a suggestion, considering that the printer was equipped with a finisher with stapler that I removed...and that simple printing/copying works without problems!!
  • djbass
    • May 2008
    • 159
    Are the leaf springs for the idle rollers (under the grey rollers) missing or broken on the exit/reverse assembly?
    No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
    • tecnomarco
      • Jul 2011
      • 213
      Thank's djbass for your replay...but the springs aren't broken
      • Rusty.Harris
        • Jan 2021
        • 621
        That being an 05 series machine, I would pull the exit unit assembly, and check the brass bushings on the main drive roller. It was common for TABS
        to apply black grease on the brass bushings on that series. It was to help avoid any moisture contamination during transit.
        But, being that close to the fuser, that black grease would dry up and harden, and it could slow down that roller, which would throw the timing off and
        cause duplex jams.
        • mojorolla
          The Wolf
          • 2584
          Replace the washered screw on the LGC board:
          • tnrtt
            • 156
            Check the gate for warping. manually lift it to see if it contacts fuser exit guide.
            • Munter
              Member
              • Jul 2011
              • 22
              The little plastic pip that the springs hook onto usually break and the spring is no longer anchored. There is a mod for this but you could also just wedge something in the hole to hold the springs in place (which is basically just what the mod is).
              • tecnomarco
                • Jul 2011
                • 213
                I changed the screw on the card and the problem seems to have been solved... I will keep you updated. I thank the user Majorolla so much for posting this modification... I can't believe that that screw created so many problems for me😠😠
