Toshiba eSTUDIO 2550c Europe
  • jampha
    • Feb 2022
    • 1
    Hey,
    I have a old secondary printer Toshiba eSTUDIO 2550c Europe that suffered a hard drive failure. I have now replaced and formatted the new hard drive, but the printer requires a firmware to boot up. Could someone maybe provide me one so I could get this device back in working order?
    Sincerely,
    exlator@gmail.com
    • 8104
    Re: Toshiba eSTUDIO 2550c Europe
    Did you install a Toshiba original SED-HDD ? An off the shelf HDD will not work.
      Originally posted by jampha
      Hey,
      Sincerely,
      exlator@gmail.com
      It's not ideal to ask for free firmware on your first post. Try making a donation to the site and you'll have a better chance at getting it. But I can't guarantee it.
      • Jasper Bürotechnik
        • Sep 2017
        • 25
          In english?
            • Sep 2017
            • 25
            In english?
            If the machine has an SSD or an HDD, they are different FW. Greetings Friedel
            • MossFold
              • Mar 2022
              • 3
              Re: Toshiba eSTUDIO 2550c Europe Firmware.
              I've only found you because I've got an F101 fault keeps coming up on my e-Studio 2550c. Turn it off, leave for 5 minutes and then back on and it's ok for a while. I'd like to update the firmware to see if it is a magical cure. Despite being trained in the art of designing and fixing all things electronic (a very long time ago) I have been ignoring this for a while. It's now bugging me.
              John
                • 22936
                John
                Sorry to say, firmware will not fix your intermittent HDD. While it's still working, quick do a clone of the addressbook.
                Replace the Wipe Drive. Re-load firmware. Re-load the clone. =^..^=
                • MossFold
                  • Mar 2022
                  • 3
                  That's not the answer I was looking for! 😂
                  Is the HDD specific to the printer or will any do? Can you tell me where it is in the machine please? Save me stripping it into 1,000,000 pieces?
                  Thank you.
                    • 22936
                    If you're going to be the technician, do it right and get the service manual. There is a very specific procedure to change the HDD and you'll need to follow it.
                    The HDD is not a standard SATA drive. It has software that wipes the contents after each use, hence: Wipe Drive. You may not substitute another type of drive. Toshiba part #: G0-00732000
                    If you don't have Toshiba contacts, try Hytec.
                      • Sep 2017
                      • 25
                      Thank you.
                      • MossFold
                        • Mar 2022
                        • 3
                        Thanks very much for your replies Blackcat4866. Perhaps I should stick to my day job and run the printer until it fails properly and then replace it. I'm not sure it's worth finding somebody local who will have all of the software and knowhow to fix this machine. I'm in Blackburn, Lancashire. Perhaps there is somebody reading this who does have the expertise to keep this printer alive as I do find it very useful.
