4555c with quality issues
  • CopierChick
    • Aug 2012
    • 85
    Re: 4555c with quality issues
    [QUOTE=blackcat4866;2114854]Take a look at the black primary charge grid tensioner. It's quite common for that plastic piece to break, then the grid lays directly against the drum, making a diagonal pattern like this. In the same way, the post can break, allowing the needle electrode to lay against the grid. Sometimes you'll get a C970. The part number is: 6LK49138000 "seesaw"
    Thanks for the help & picture too!
    This part as pictured below, correct?
    If so unfortunately no one seems to have that part in stock but basically I could also replace the entire black drum unit/cleaner unit (pictured below- part # 6LJ70686000) and it should take care of the issue, right?
    I just need to make sure it will take care of the issue when I show up at the customers office as they were not very happy to replace the transfer cleaning unit and waste toner bottle and not have the issue resolved. I explained that those items needed to be replaced either way but you know how customers are! Lol
      • 23007
      Yes, the drum will have that part.
      Also try the old style part number: (looking it up now)
      6LJ54234000
      • CopierChick
        • Aug 2012
        • 85
        6LJ54234000
        The drum unit with cleaning unit took care of the issue! So thankful for all the help!!
        You guys rock!
          • 23007
          #19
          Congratulations on your success! =^..^=
          • CopierChick
            • Aug 2012
            • 85
            #20
            4555 Toshiba .jpg So since this machine has been weird I just wanted to verify what you might think the issue is, cyan drum unit??
              • 23007
              #21
              First, I want to confirm that those lines are crossfeed. If they are, what interval do they repeat (in millimeters, please).
              From what you've shown me, I would suspect that the cyan developing unit is seizing up. If you try to turn the cyan developing unit you may hear the clicking of gears skipping, or it may be very difficult to turn, or you may notice one of the drive coupler prongs broken off. Usually it will be accompanied by a pile of cyan developer leaking out the back of the unit, and you'll see developer in the drive gear teeth. If that's the case it will need a cyan developing unit rebuild. Can you provide a better sample?:
              • CopierChick
                • Aug 2012
                • 85
                #22
                  • 23007
                  #23
                  Yes, lines are crossfeed. =^..^=
