4508 KD-1059
  • tnrtt
    • 156
    4508 KD-1059
    Have a strange LCF problem. Load both sides of the LCF and boot up. Shows both sides full. Run 1 copy, then right side shows empty. Reboot and will show full again. Key in 5 and will run all 5, then show empty after completion. Carry a feedhead with me and swapped it, no difference. this was at end of day when they were closing. disconnected LCF and said I'd be back. Error history showed a lot of C1B0 and C180 codes. I'll research it this weekend. Any idea's would be appreciated. I have a KD-1058 I can put on it if it's not an easy fix. Thanks
    • 23010
    Re: 4508 KD-1059
    There are only two motors on the KD-1059, and both are erroring out, so I suggest rechecking all the connectors inside the KD-1059, and to the machine. There's also a possibility that there's a pinched wire in the KD-1059 harness. If it persists (which it will) it can be either the LCF controller or the logic board, 50/50 either way. I'd probably go for the LCF controller first, only because it will be cheaper. =^..^=
    • tnrtt
      • 156
      Re: 4508 KD-1059
      Thanks BC. That was the ticket. I figured as much.
        • 23010
        Re: 4508 KD-1059
        Thanks for following up. =^..^=
        • Rusty.Harris
          • Jan 2021
          • 639
          Re: 4508 KD-1059
          I WISH they would provide maybe an extra 1/4 inch of cable, to connect these to the color machines.
          Pop off the back, unhook one of the clamps gives you enough cable, but you have to pull the back cover off.
