5005ac waste toner
  • tnrtt
    • 156
    5005ac waste toner
    Have a 5005ac giving a false waste toner message. Sensor(s36) read bad in test mode. Replaced sensor to no effect. Can't find it on the wiring diagram. The grid location for it is blank. Anybody have the grid coordinates?
    • 23009
    Re: 5005ac waste toner
    S36 WTNR-NFL-SNR
    Waste Toner Amount Detection Sensor
    The reason you can't search it is that there's a mis-print in the wiring diagram. It's incorrectly listed as S35 at C8, diagram 14.2.2, pg 1162. It's odd: Even the "S35" does not come up on a search. =^..^=
    • tnrtt
      • 156
      S36 WTNR-NFL-SNR
      [ATTACH=CONFIG]53067[/ATTACH]
      Thanks, BC. Wound up being a logic PCB. Does Toshiba offer a readable full size schematic for this?
        • 23009
        Not sure about that. If the search fails, I just blow it up to 300%, and creep along until I find what I need. It was just serendipitous that S36 was at the top left corner of the diagram (where I started). =^..^=
