Toshiba 5506AC Dark band
  • bcopier2815
    • Oct 2015
    • 42
    I have a Toshiba 5506AC that has large dark bands as per the attached image. Yes, I do have the manual but I don't see anything that explains this. Long time Kyocera/Ricoh tech and I have never come across this. Any Help would be appreciated sample.pdf
  • Jettdog
    • May 2021
    • 48
    Re: Toshiba 5506AC Dark band
    Have you removed the transfer belt and looked at it?
      • 23009
      Since it seems to affect all the base colors equally I'd suspect 2nd transfer. =^..^=
      • Logged-on
        • Sep 2010
        • 197
        If it's not second transfer, I'm wondering if there's an obstruction in the optics. If it's calibrating to the white plate, and there's an obstruction, perhaps that would be your result. I can't say I've seen that before though.
        • Rusty.Harris
          • Jan 2021
          • 634
          What kind of enviroment is the machine located?
          I had one that was in a metal fabrication office, and the machine was located RIGHT NEXT to the door that
          went to the shop. I pulled the laser and there was a band of dust, in the same place, on all four mirrors.
          Also, the polygon mirror was etched. Dark on one edge and lightened up to the other edge.
          I cleaned the laser mirrors, replaced the polygon motor/mirror assembly, and used foam tape around the inside
          edge of the laser cover, and the heat sink for the laser motor. Problem disappeared and no issues with the
          motor overheating.
          I called the hotline to let them know what I found and they said "you can't take the laser apart, it's a sealed unit"
          I told them then why are there screws holding the lid on? I also said hey, no pain no gain. It was already broken
          so I had nothing to lose.
          • Alexjam48
            • Dec 2021
            • 1
            Originally posted by bcopier2815
            I have a Toshiba 5506AC that has large dark bands as per the attached image. Yes, I do have the manual but I don't see anything that explains this. Long time Kyocera/Ricoh tech and I have never come across this. Any Help would be appreciated [ATTACH]53390[/ATTACH]
            I have the same exact problem with a Toshiba 5506AC, were you able to resolve your issue? We are going to replace the 2nd transfer roller, but my guess is that it may be the laser unit. Thanks.
            • Rpizzle
              • Mar 2014
              • 47
              How do you print off the test charts on toshiba? kyo tech. I'm having to work on a toshiba estudio e6506ac.
              • dak327
                • Jun 2016
                • 4
                I have this exact issue. Has anyone figured this out?
                It's definitely an internal print issue and has nothing to do with the optics
