toshiba es3515ac ca00 error
  • tee
    • Aug 2014
    • 79
    [CQ] toshiba es3515ac ca00 error
    tried calibrating and fails every time. copier just had black pm.
    image sensor shudder modification was done also.
    the patches are printed on the belt. black prints are somewhat blurry, but
    color prints and copies are very bad. see sample copy.
    • 22999
    Re: toshiba es3515ac ca00 error
    If the post for the patch sensor breaks, the shutter does not open correctly you'll get very poor calibrations. Is this the modification that you're referring to? Let's see if I have a photo ... yes, take a look at these:
    The shutter must be able to operate to view the patches on the primary transfer belt. And yes, you'll get CA00 errors and very poor quality images. That's where I would start. =^..^=
    • tee
      • Aug 2014
      • 79
      Here is the update that was done
      see attached
        • 22999
        That's the one. Just make sure that the shutter is installed correctly and can move by itself. Did you do a color calibration after the bracket was installed? =^..^=
