Toshiba eStudio 5506AC / Message icon
  • printer123
    • Jul 2022
    • 4
    Hello, I have a Toshiba eStudio 5506AC , does anyone knows how to remove or delete a "message" on the bottom left side of the screen? Thank you
    • 8197
    Re: Toshiba eStudio 5506AC / Message icon
    ... press the yellow clear hard key twice. What is the message?
      • 23007
      It depends on the message. What was it again? =^..^=
      • printer123
        • Jul 2022
        • 4
        I pressed the yellow twice and it didn't do anything. the message is lan cable is not connected and there is another message have a phone number.
          • 23007
          Is the LAN cable connected?
          What was the other message?
          • mojorolla
            The Wolf
            • 2609
            The LAN cable message simply means the machine cannot detect the network cable is plugged in. Make sure the device is not set to a static ip and DHCP is enabled.
            The phone number is the "banner" message in service mode. You can edit these setting in 08-9327,9328,9329, and 9330.
            • Rusty.Harris
              • Jan 2021
              • 630
              If it isn't connected to a LAN, you can disable the message in admin mode I believe.
              • dickrick johnston
                • Jul 2022
                • 1
                have you tried plug
                ging in a lan cable?
                • printer123
                  • Jul 2022
                  • 4
                  The LAN cable issue is fixed. Can you please tell me how to get to remove "banner" message. The steps to get to the setting? Thank you
                  • mojorolla
                    The Wolf
                    • 2609
                    With the machine off, hold down the Function/Clear and Start buttons. Turn on the main power while holding these 2 buttons. Password is #1048# Select 08 setting mode, upper right-hand corner, touch Classic. You can then enter the various 08 codes with the on-screen keypad. Enter the code # (9327) then hit Start, enter the new value, then OK to save the new value. To exit hit FS menu, then Normal on the touch screen.
                    Below are the 4 settings and what they do:
                    • printer123
                      • Jul 2022
                      • 4
                      [ATTACH=CONFIG]54041[/ATTACH]
                      Thank you very much!!!! It worked
                      • mojorolla
                        The Wolf
                        • 2609
                        We use this banner to put the machine ID number and our service phone number.
                        Who needs stickers when you have technology!
