e Studio 2500ac wanted firmware
  • 123Stairs
    • Sep 2022
    • 5
    [Electrical] e Studio 2500ac wanted firmware
    Hi.
    Can someone help me? I am looking for firmware for the eStudio 2500ac printer. I had an error F101 13 and from what I found out I need a new firmware.
    Lest there be a mistake, I enclose the plate from my printer.
    • 23010
    Re: e Studio 2500ac wanted firmware
    You'll need firmware, yes, but you'll probably also need a HDD.
    Were it me, I'd follow the test procedure on pg 826 of the manual, which will help you determine if the HDD is bad. =^..^=
    • 123Stairs
      • Sep 2022
      • 5
      Thank you,
      I would definitely do this procedure, but I don't have a service manual. Can you send me the entire manual or at least page 826? Please
        • 23010
        There you go. When you get to the part about formatting the HDD, if you format the HDD your firmware will be gone.
        • 123Stairs
          • Sep 2022
          • 5
          Thank you very much.
          I am at the stage of disk format, which means I will definitely need firmware. Can you help me?
            • 23010
            I've heard that members that contribute to this website often get their wishes. =^..^=
            • 123Stairs
              • Sep 2022
              • 5
              My stupidity was that I watched a movie on YT where a "specialist" suggested step by step how to save my printer when there is an error F103. Of course, it appeared there that I MUST format the disk. Later it turned out to be a scammer but I have a big problem now
              Here is a link to a movie on YT, maybe someone will not be fooled by it:
              • lazzimau
                • Jan 2023
                • 8
                hi, i'm looking for e-studio 2500ac firmware, i've formatted hdd after error F101 and now i think i need a new firmware to upload by usb, right?
                thanks a lot
                • aalex_bom
                  • Jan 2008
                  • 214
                  thanks a lot
                  check PM, please
                  • lazzimau
                    • Jan 2023
                    • 8
                    to update firmware from usb i have to put in the usb the file mentusb2.o and the folder 2000AC_2500AC, right? i don't have the file mentusb2.o, help me please.
                      • 23010
                      The last machine that needed the mentus2.0 file is the eS350.
                      Extract the firmware file, & copy the extracted files to the USB stick. Power on into 49 mode ...
                      • lazzimau
                        • Jan 2023
                        • 8
                        in the usb i've the folder 2000AC_2500AC but when I press normal update the printer goes back to the f101 error screen and everything is blocked and I have to turn it off by unplugging it
                        • lazzimau
                          • Jan 2023
                          • 8
                          i tried with 2 different firmwares, but still the same result, it goes back to the f101 error screen and everything is blocked.
                          the hdd formats without problems
                          Thanks for your help
                            • 23010
                            There's a very small chance that you've got a bad system board. Much more likely, it's a bad HDD ... yes, even though it will do a format.
                            I've seen one bad system board for issue, and maybe hundreds of bad hard drives. =^..^=
                            • lazzimau
                              • Jan 2023
                              • 8
                              thanks for your reply.
                              so i have to change hdd. do you have a manual to disassembly the printer? is it a normal 2.5 hdd?
