Help - print on both sides of custom paper size 4505AC
  • longyen.hcm@gmail.com
    • Jan 2023
    • 13
    Hi Guys, im new to Toshiba, i need to print on both sides of custom paper size, i ve set 210mm x 325mm Drawer 1, then i cant not use duplex, just 1 side available. Is there any chances to print on both sides of this custom paper size.
    Many thanks for your help. Thank You
    • 23010
    Re: Help - print on both sides of custom paper size 4505AC
    If you have one of these size options: US Folio = 210x330, or Foolscap Folio (British Imperial Cut), or SRA4, or F4 Southeast Asia, or C4 Envelope, or Oficio (Colombia) it should work. A difference of 5mm in page length is usually not detected as a jam.
    Most often for me, it's envelopes that are odd sized (difficult to set up), so I wrote this procedure for #9 envelopes. You'll have to make the appropriate alterations for your custom paper size, media type.
    For US users: There's a quirk on Toshiba devices. You have to ability to enter inch measurements into the print driver, but not into the MFP screen. So even if those measurements are properly converted, the exact inch measurement will not size match with the exact metric measurement. Always user metric measurements on both.
    On your PC:
    Search > Printers & Scanners > open queue > Printers > drop to Properties > Preferences > Other > Custom Paper Size > Add > set A (short dimension in mm: 100) > set B (long dimension in mm: 225) > name the new paper size "Envelopes9" > OK > Apply. When printing select the new custom paper size, select Envelope media type. When the MFP asks for UNIV, load envelopes SEF (short edge first), face down, 12 or less quantity, to the bypass tray (move green handle, insert envelopes, release green lever).
    Since you are using Plain media type, you should be able to select duplex in your print driver. This setup will request loading the media to the bypass tray. In the User Menu you have to option to set up a Custom Paper size. If it is the exact same measurements and same name that you selected in the driver, it should choose that paper and be able to duplex.
    Complicated? Yes, but it works. =^..^=
      • Jan 2023
      • 13
      On your PC:
      Great, so many thanks it works with Folio. Thank You and have a great day sir
        • 16479
        On your PC:
        I bow before thee.
        • pacman
          I can turn a screw...
          • 318
          On your PC:
          I'll take "Things I had ZERO clue about" for $500.00, Alex...."
