456 E061/62
  • Rusty.Harris
    • Jan 2021
    • 634
    456 E061/62
    Tech just called me. Had a 356/456 that tray 1 & 2 are showing E061 & E062
    Tray one letter-r, tray 2 legal. Tray 3 is the LCF.
    He changed paper sizes, no change.
    He's replaced both paper feed units, no change. No paper scraps at the back of the feed area either.
    Other than a pinched wire harness...only thing I could think of would be the paper feed board or
    logic board.
    Any other thoughts?
    • 23009
    Re: 456 E061/62
    There are a couple of new things here: registration switches, sector gears or loose mounting screw, loop adjustment ...
    Loire:
    Misfeeds from tray #1 (E061). "Load LTR paper." or "Load paper to bypass tray." Worn registration roller flags. Other consequences: Ripped tray #1 separation roller, separation guide dislodged, and cracked lift sector gear. Replace registration roller flags (6LH56318000, 6LH56319000), PM-KIT-ROLLER (6LH34608000), and sector gear (6LJ11607000).
    Misfeeds from tray #1 (E061). "Load LTR paper." or "Load paper to bypass tray." Worn tray #1 paper feed rollers. Replace tray #1 rollers (6LH34608000).
    Misfeeds from tray #1 (E061). LT-R paper is loaded in tray #1, but programmed as LT. Program tray #1 to appropriate size: User Functions > Drawer > select drawer > select appropriate paper size.
    Misfeeds from tray #2 (E062). Paper size mismatch. Tray #2 was loaded LT-R, but programmed LT. Re-orient paper in tray #2 to LTR, to match current settings.
    Misfeeds from tray #2 (E062, E065, E140). Z-folds each page before the fuser. Loop out of adjustment. For large size paper tray #2, set 05-452-0 from "20" to "10".
    Loire X:
    Misfeeds (E061). Paper in tray #1 has been re-positioned to LT-R, while still programmed for LT. Re-position paper or re-program paper size tray #1, either so they match.
    Misfeeds (E062). Paper in tray #2 has been re-positioned to LT, while still programmed for LT-R. Re-position paper or re-program paper size tray #2, either so they match.
    Misfeeds (EB50, E061) accompanied by noise when paper is near end, from tray #1. Inadequate paper lift. Paper lift gear is loose, but not broken. Secure and thread-lock the sector gear screw.
    Misfeeds (EB50, E062) accompanied by noise when paper is near end, from tray #2. Inadequate paper lift. Paper lift gear is broken. Replace and thread-lock the sector gear (6LJ11607000).
