E-studio 5506AC - Error F150 / F140
  • Shanabat38
    • Mar 2023
    • 1
    Hi, I have a toshiba e-studeio 5506AC, when I turn the machine on sometimes it gives me error F150 and sometime error F140. Anyone can tell me how to fix this issue? Thank you
  • mgipa
    • May 2020
    • 49
    Re: E-studio 5506AC - Error F150 / F140
    Set the value of FS-08-9010 to "0".
    • tech07
      • Aug 2008
      • 409
      Clone the machine and order a HDD. Even if it's working now, it will most likely fail again
      • Rusty.Harris
        • Jan 2021
        • 621
        Go into HS mode, run the HDD diagnostic test and see if you have a damaged file/partition.
        Most likely the HDD needs to be replaced. It MUST be replaced with a "wipe" drive, not a standard
        HDD.
          • 22997
          The F140 is an ASIC format abnormality, quite possibly caused by the System Board.
          The F150 is a power supply failure during manufacturer mode. The manual does give any details, except to enable FS08-9010 to "0" then look up the resulting error.
          Actually neither of these errors appear in the eS5506AC service manual at all. You can find details in the more recent eS5516AC service manual.
          If you're an enduser, you'll probably need the services of a technician. =^..^=
