5516ACT out of box failure
  • Rusty.Harris
    • Jan 2021
    • 632
    This was a fun one. 5516AC, with MJ1113B
    After developer stir, CE20. Went into 08, disabled,
    powered on, then CA00. Disabled that, then it
    said the error was comm failure between finisher &
    logic.
    So I said screw it, disconnected the finisher, flashed
    the copier. Connected the finisher back and it was
    good to go. enabled the color calibration & registration
    and worked on that. 03 mode shutter opened and closed
    but the 03 input mode said the sensors were not changing.
    pulled that all apart, connectors looked ok, but reseated
    then, powered back on and that fixed it.
    • 23008
    Re: 5516ACT out of box failure
    So its working ... for the moment?
    This machine clearly never cleared quality control, and nobody tried very hard to diagnose the various issues. =^..^=
      • 8208
      logic.
      ... a recent TABS service discussion on FYI.toshiba.com stated that when asked to reseat connectors, technicians should not just use hand pressure to push the connector against the board pins, the technician should actually physically seperate the two and then reconnect them.
      • Rusty.Harris
        • Jan 2021
        • 632
        Yep, I remember that discussion. That's why my fingers are sore. Unplugging and reconnecting every connector LOL
        I use to think it was they wanted the connections to be secure, on a trip from the Earth to the moon, but I think it is
        to survive the trip on the slow boat from China.
