e-studio 5540 cse Smearing and coverage
  • ThomasM
    • Feb 2022
    • 12
    • 23010
    Re: e-studio 5540 cse Smearing and coverage
    The samples that you have attach show developing issues for CMY & K. Are you aware of the difference between developer and toner? Most likely the developer is dead (not the toner). =^..^=
    • ThomasM
      • Feb 2022
      • 12
      Yes, I ordered developer from aaa toner which was especially for Toshiba.
      Also replaced toner cartridges as they were empty.
      I cleaned out the developer before adding the new developer.
      • Rusty.Harris
        • Jan 2021
        • 639
        Did the developer come in the cartridges, where you remove the cymk sub hopper assembly, insert the developer
        cartridges, and then go into "easy setup" which adds the developer, then calibrates the developer?
        • ThomasM
          • Feb 2022
          • 12
            • 8323
            The e5540 was launched in March 2011 and discontinued in May 2012. All technical support, parts and supplies are no longer available from Toshiba Tec.
            Why you want to put good money into this old copier is up to you.
            • Rusty.Harris
              • Jan 2021
              • 639
              No.
              Do I need to get the $1600 developer cartridges to make It work better?
              Not really, but you need to run the developer calibration along with the image
              calibration in 05 mode
              • Service Call Assassin
                • Jun 2023
                • 4
                If the 5540c's have a discharge led array, they could be caked with toner causing the drum to not discharge and constantly pull toner/ developer. "The tiger stripes" or "Feathering" is usually caused by developer depletion. The developer becomes worn and rounded over time due to not necessarily output counts, but drive counts. Seals leaking on dev augers can cause this too. among 20 other things lol.
