Toshiba 3505AC with partial background?
  • Buddy
    • Aug 2009
    • 285
    Hi folks,
    I have a es3505AC there is shading on a portion of the page. I've changed the developer and the drum. Did not make a difference. And ideas? Thanks
    shading.pdf
    Re: Toshiba 3505AC with partial background?
    Originally posted by Buddy
    Hi folks,
    [ATTACH]58567[/ATTACH]
    copy print or both?
      • 23009
      Same question, different words: Have you ruled out the scanner optics yet? =^..^=
      • Buddy
        • Aug 2009
        • 285
        copy print or both?
        Both
          • 23009
          Have you looked at the black primary grid yet? I expect that it will be a pretty shade of green. Or perhaps the seesaw is broken and the grid is laying against the drum. =^..^=
          • Buddy
            • Aug 2009
            • 285
            I have not Black Cat. I'll check it out. Thanks
            • Rusty.Harris
              • Jan 2021
              • 634
              Also check the interal test print to absolutely rule out the optics.
              • Buddy
                • Aug 2009
                • 285
                Thanks Rusty. I did.
                • Buddy
                  • Aug 2009
                  • 285
                  Once again, you were right on Blackcat! Grid was green. Replaced it and all is well with the world.
                  THANKS AGAIN
                    THANKS AGAIN
                    be sure to click on the star {lower left of BC's post) and give him good reveiws please.
                      • 23009
                      THANKS AGAIN
                      Congratulations on your success. =^..^=
