estudio 4515 LCC jams
  • doc538
    • Feb 2014
    • 8
    I have a 4515 in the field that only jams from the LCC. We have replaced the feed tires, sep rollers etc. The paper feeds out of the tray and hits the first turn rollers where the paper folds and then proceeds to the next roller assembly. It appears the primary roller is not starting quickly enough; it does spin but it must be late. As usual its in a place where they are always pushing us out the door so no chance yet to disassemble the unit, also We do not have a service or parts manual that covers the LCC. I didn't see any sensors. Any suggestions would be greatly appreciated.
    • 22960
    Re: estudio 4515 LCC jams
    Start with getting the service manual and a jam code. =^..^=
      • 8110
      For starters, are you talking about the KD1059 LCT?
      What firmware is the copier at?
      How many clicks are on the copier?
      • doc538
        • Feb 2014
        • 8
        Ya, Not very helpful! Not a dealer, can't find a manual on the lcc but hey thanks anyway.. Sure miss Smarka.
        • Hadster
          • Aug 2011
          • 264
          These LCC feed units are the exact same feed units as in a Ricoh, so I am very familiar with this. On the feed roller shaft you will want to scuff up the shaft a little for the one way bearing to grab. There are two, one on the drive gear beside the feed roller and one in the feed roller it self. Also, if this doesn't do the trick replace the feed clutch. One or both will solve your issue. FYI, sorry for the welcome committee but next time you will want to come with more info otherwise you can get hammered on this site. We get a lot of end users asking questions they should not be asking and it gets a little old. Just saying.
          • doc538
            • Feb 2014
            • 8
            Hey thanks for the input! The feed rollers are performing well, it's the first turn roller that "Seems" to be late. I thought I had provided sufficient information for a decent reply but I guess not. In my area, we have mostly Konica's, Kyocera's, and HP's in the field. very few Toshiba's and almost no Ricohs anymore.
            I was looking to see if anybody had a manual or any info on how the turn roller clutch is set up. This is a customer who is always pressured for time, being a church, I would think they would be a little more patient, but the pastor is always in a hurry to Leave, so I have not had the time to disassemble the unit.
            As for the welcome committee, they are always fun. I have been coming here longer than a lot of these "techs" have been working, just not often, only for the weird units.
            Join Date02-12-2014
              • 22960
              I am a strong believer in karma.
              Those that give will also receive. Some can give advice. Some can give a small financial donation. Some give neither. I noticed that among some younger members that "forum" is synonymous with "free". You seem old enough to know better. =^..^=
              • doc538
                • Feb 2014
                • 8
                Another needy person that just has to post nonsense heard from! Problem was solved without your assistance , AS USUAL.
                • Hadster
                  • Aug 2011
                  • 264
                  blackcat rep power= 453
                  your rep power = 0
                  blackcat = contributor
                  your contribution = nothing
                  Hmm....Who am I going to listen too!?
                  • doc538
                    • Feb 2014
                    • 8
                    your rep power = 0
                    Like I care! As stated problem solved without any help from here, not much help anyway mostly little snarts like this one. GROW UP! If you can't help then just move on to the next one you cant help.
                    On the Smarka board there were professionals who responded and there We were frequent collaborators to help out other pro's. Not so much here as you all sound and act like the kids on facebook groups.
                    Bad on me for wasting my time even posting a question here. Don't bother responding children as I will no longer read or respond.
                    • Logged-on
                      • Sep 2010
                      • 197
                      I think the problem is that the 4515 has 2 different LCTs. There's the TLCF the tandem tray available for the base of the machine and the OLCF that's available as an outside option, so that is why more information was requested.
                        • 8110
                        .... it was not until the following series, the e4525AC, was an external LCT made available.
