I have had several instances of IH board Visibly blown at the IGBT circuit has anybody else been seeing this, if so what is causing it. Some machine have less than 20K
IH board blow out on ESTUDIO 853
alanroper
Sheet!
It is usually a faulty IH coil that will take out and IGBT board.
I have seen only several occurances of this over the last 10 years or so of IH coil use by Toshiba.
Several on the one model should be reported immediately to Japan!
Good luck -
Yes Travis I have Seen this, several times in this series. In Fuser and LCC ,(Not for nothing but they are pretty cheap connector's) however in the instances I am concerned about I found no problem. replacement of IH Board is the only corrective measure
Thanks for the input it is appreciated.Comment
I remember when that RIO series came out, they Toshiba sent us a bunch of IH boards to replace in our already in the field machines. I have had one e520 blow the circuit breaker in an office everytime they flipped the power switch on. It ended up being the IH board with no sign of anything physically wrong with it.Comment
