Toshiba 385s invalid factory configuration problem
  • Hassann
    • Jul 2023
    • 85
    Hello everyone
    I have a problem with Toshiba 385s show message " invalid factory configuration" and " replace unsupported cartridge"
    Need help pls
  • tsbservice
    Field tech
    • 8052
    Re: Toshiba 385s invalid factory configuration problem
    Set correct date and time in web page.
      • 23010
      This is a Lexmark rebadge. Check that the toner cartridge contact set is not broken or damaged. =^..^=
      • Hassann
        • Jul 2023
        • 85
        I set the right time and I tried three versions of fw but nothing fixed
        • Hassann
          • Jul 2023
          • 85
          It's not broken or damaged it's ok I'm sure
          • Blizzoo
            • Aug 2013
            • 610
            Have you tried a simple Factory Reset?
            If you think the toner cartridge is ok, to me it sounds that your machine might have come from a different Region or something? Maybe a setting on one of the menus?
            • Hassann
              • Jul 2023
              • 85
              Yes I have tried
              It's was working well that problem become after format factory and clear memory
                • 23010
                Could it be that it had a Lexmark toner cartridge installed, not a Toshiba cartridge? Or vice-versa? I'd think the EEPROM would be coded differently. The reset may have changed the manufacturer to Toshiba. Just out of curiosity, if you go to the web interface, what model and manufacturer show on the screen? =^..^=
                • tsbservice
                  Field tech
                  • 8052
                  That was exactly what I thought. Recently bizhub 4050 and so started to exhibit the same messages and we all know they are Lexy rebadges. Same can apply for Toshiba equivalent.
                  Just a thought as I really don't have an idea what beast is 385s, by 3 digits I could guess it's A4 model but that's all ๐Ÿคฃ
                  • arnh79
                    • 469
                    When Toshiba first started selling rebadged Lexmarks, I was told by a Toshiba engineer that if you put the Lexmark FW on the machine instead of the FW files from Toshiba it will break the toner chip recognition. I never tested it, but I'm wondering if that may have happened here?
                    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
                    • Hassann
                      • Jul 2023
                      • 85
                      Toshiba model in web interface
                      • Hassann
                        • Jul 2023
                        • 85
                        I will try Lexmark toner but Which Lexmar model is the same as the Toshiba 385s?
                        • Hassann
                          • Jul 2023
                          • 85
                          Which Lexmar toner chip i have to try
                            • 8284
                            This long ago discontinued Toshiba/ Lexmark model (not sold in North America) was introduced in 2014. Support is no longer available, you are likely wasting your time.
                            This product is not even listed in Web ribon.
                            • jonwill
                              • Jan 2017
                              • 10
                              MX310, MX410
                              385p & 385s
