Toshiba 7508
  • Joe Foe from Buffalo
    • 394
    [Electrical] Toshiba 7508
    Toshiba 7508 black and white machine. Background like it's losing bias. Technician performing preventive maintenance replaced drum unit charge units development unit developer. Possible cause ITB Assembly electrical spring connection near the drum unit connection. Randomly can pull the drum ITB assembly out of machine push it back in it'll go away for a couple hundred copies. Click on the link for sample of image
    Shared album - Joe Foe from Buffalo - Google Photos
    • 23006
    Re: Toshiba 7508
    It's a negative, that's interesting. Thanks for sharing. How much confidence do you have in that solution? =^..^=
      • 394
      Re: Toshiba 7508
      Thank you for non constructive response. Hopefully you feel better doing so. FYI I've been a technician that works on anything from a-z that uses paper since 1980... That yes sometimes I ask for help. This machine is in a prison in the population. Can't take anything more than a screwdriver 99% of the time an being watched talked to all of the time by prisoners an guards want me out of the machine, area asap
        • 8179
        Re: Toshiba 7508
        ... perhaps you have been in the industry for too long because when your first response is to sh*t on responders, this does not make one want to reply.
        I have worked on copiers in prisons and I know the process is onerous. We eventually got rid of this kind of client for greener pastures.
        Why a copier is accessible to any prison population is a big no no by itself. There are lots of sharp metal objects and glass inside a copier. The copier should be in a secure Admin area. I would decline all service until the copier is moved into a safe work area for yourself.
          • 23006
          Re: Toshiba 7508
          So there's no solution. Now I get it.
          I usually try to address questions as they come up, and there weren't any questions in your post. I don't mind a little snark in the response, but I think I'll just let this one go by, thanks. Good luck. =^..^=
            • 8179
            Re: Toshiba 7508
            The e7508A was introduced in Sept 2016 and discontinued in March 2018.
            This copier needs to be upgraded to a e7529A to reduce your service calls.
              • 394
              Re: Toshiba 7508
              Sad seems like this tech page is going down the tubes with helping fellow technicians since I've used it last. 🖖🏻
              • tsbservice
                Field tech
                • 8003
                Re: Toshiba 7508
                Actually it isn't and still providing very valuable information and help for us technicians.
                Just my opinion.
