e-studio 305/338(lexmark)
  • sappa12
    • Sep 2023
    • 57
    just asking.....has anyone ever try to dissamble scaner/original glass to clean underneath it.Is it even doable or you could do more damage then good
    • 8320
    Re: e-studio 305/338(lexmark)
    Far easier to drill a hole in the side of the plastic and insert a cleaning tool. When finished cover the hole with grey coloured duct tape.
    These are old discontinued product that should be replaced.
    If you could find a top deck assembly it would be expensive and very labour intensive to replace.
      • 23010
      Are you sure about that model number? the eStudio 305 is a Loire (Toshiba build, not Lexmark), and I can't find any reference to a Lexmark 338 on the internet. =^..^=
      • subaro
        • Oct 2010
        • 1274
        So, if the glass is dirty, what about the mirrors, how you gonna clean that .
        Lexmark has some models with the scanner being a bit of work to get the glass off. They can all be removed and cleaned. The key thing with lexmark is you have to follow the instructions on how to remove the covers to remove the scanner area or you would break the tabs that hold them on the machine frame. On the field it might be a challenge , but if you have your wits, then it is definitely doable.
        • sappa12
          • Sep 2023
          • 57
          i name toshiba models like e-305,e-338cs,e-425s,e-385...."lexmark" models....because they are lexmark based. just my thing
