Toshiba eStudio 2540cse EC970 or black withe service mode code.Regards!
  • CristiI
    • Nov 2023
    • 12
    I have error C970 on machine Thosiba e studio 2540cse. I checked every cylinder, everything looks K, inside the contacts seem K.Se I can see clearly, the blades on the cylinders are firm and clean. I understand that there can be something in short on the cylinders. What do I need to measure? WITH what codes can I check each cylinder. In the worst case, how can I cancel the color cylinders, so that after booting only black and white goes. But let it go. Thanks in advance! Cristi
  • Thayer
    • Dec 2017
    • 108
    Re: Toshiba eStudio 2540cse EC970 or black withe service mode code.Regards!
    Pull image units and look for broken lever on charge grid (s). If charge grid/saw tooth is not tight or throws that code.
      • 8252
      You need to give up on this copier that was discontinued in May 2012. Toshiba Tec Japan no longer supports it with parts and supplies.
      This was an overly complicated and heavy weight design from the past.
      • CristiI
        • Nov 2023
        • 12
        Image units and look for broken lever on charge grid (s). If charge grid/saw tooth is not tight or throws that code.[/QUOTE]
        The window teeth are whole, but the piece somehow plays left right at each image unit. I mean, she's not firmly caught. The HVT board seems in order, I didn't find anything squeezed by electric arc.. If you know any codes I can try each cylinder individually. Maybe I find the faulty one, and using another code, to cancel the color part, so it remains black and white. I didn't understand the electrodes part in short on the cylinder. Where should I measure? THANKS! wire break,
        its side charger or main charger?
        I have service manual if you need. tehnicdti@gmail.com
        • CristiI
          • Nov 2023
          • 12
            • 23010
            Rear charge block1.JPGRear charge block2.JPGScorotron tensioner.JPGseesaw.jpg
