es-35
  • smiley
    • Aug 2008
    • 615
    es-35
    hi guys this machine pulling dev so bad.i check the metal plate under developing unit check the connection tested good but still pulling the dev goes to waiste toner tank.please help me.
    there is no glory without sacrifice
  • mitsubee
    • 176
    Dear Smiley.... first take out the dev tank....you will notice a cooper pin there ( dev tank sat on it ) please make sure then when the dev tank were slotted in with a proper connection from the dev metal plate below and the cooper pin....it may help...if you wanna be sure.... connected the pin with a wire and put it outside and directly tie it up to the magnetic roller connector...
    thanks
    • Harry
      • 228
      check also drum grounding e eraes led array unit.sometimes the Drum Remaining charged and this causes your fail
      BR
      • smiley
        • Aug 2008
        • 615
        hi how can i check the drum erase led?
        • Harry
          • 228
          hi
          make a copy with the frontcover open look at left side of charge corona the led have to determ front and age of the copy also if copier try to load toner and drum turned.how ist the surface of drum is much toner on it its a drum grounding problem.
          • ivovb
            • 695
            Check metal fly wheels on both ends of drum if presents.
            BR
            I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
            • smiley
              • Aug 2008
              • 615
              there is no fly wheel present on the drum because the drum is just after market.there is alot o toner present in drum assy. and the dev goes in waist toner tank after 1k of copy.
              • ss12
                • Jul 2008
                • 289
                replace the white spacers on the developer unit.if these are worn,this can cause dev to be pulled across to the drum
                • Harry
                  • 228
                  developer
                  at first thing take of the flee weels from the old drum and change to the new one.this weels are not include also with orignal drum have change them also.if i remember right also drum grounding dependence.
                  good work
                  • smiley
                    • Aug 2008
                    • 615
                    ok guys thanks for the reply i will put the fly wheel to new drum and i let will let you know the result.
                    • emujo
                      • Jun 2009
                      • 3009
                      Drum flywheels have no effect on pulling developer, just image quality (Smoothing). Poor drum ground, dev bias, more likely culprit since you are pulling developer so quickley.Ed
                      • hoff247
                        • Jul 2009
                        • 25
                        bad or unplugged erase lamp will cause this problem. I had to replace a toner bottle couple gear and forgot to plug in erase lamp. Copier worked for about a month, then I got light copies. Developer was in waste bottle. Good luck.
