Toshiba 3511 not printing bullets??
  • CopyDawg
    • Dec 2008
    • 74
    I have an imagistics cm3530 (Toshiba 3511) that is connected to my vista computer. For some reason it is not printing Bullets of any kind on my documents... is this a setting or something?? Any help would be appreciated!
    Thank you!
  • sdrawkcab
    Confused & Bewildered
    • Jun 2009
    • 317
    What driver are you using, PCL or PS, what is the firmware version?
    Some days, it's just not worth chewing through the restraints
      • 23009
      That was my idea too. Try changing printer emulation to see if it helps.
      • emujo
        • Jun 2009
        • 3009
        If you're using the PS driver, try choosing print as image under advanced option in the driver page.
        • TheOwl
          • Nov 2008
          • 1732
          If you go into the printer properties, there should be a tab called 'Font'. In here you should find a substitution table. You need to disable the font substitution and set an option (can't remember what it is called) to 'Download Fonts as Bitmap'.
          This should then drag down the fonts with your print job rather than using the pre-installed fonts on your copier.
