I have three Toshiba 3100c color copiers and all of them run and copy very well. They don't however duplex out of the ADU for some reason. They start to duplex but then stop in the exact same place every time. I've done everything I can think of and everything the repair manual suggests. I've switched adu's around and each one does the exact same thing. I've also replaced sensors thinking that might have something to do with it. Anybody have any ideas?? Thanks in advance.
3100c Duplexing problems! -- Out of ideas, help!
had a faulty clutch in a dup 3511 once ... whats the error code ?
*9 power on ...106 ..press start to get codes
by the way what firmware?
does it do it from the glass as well? m or only from doc feeder? ... how about printing fropm pc?Last edited by fireater; 09-29-2009, 02:10 AM.I fix copiers ...Well SortaComment
The question would be "Where is it stopping?"
If the paper stops as it's trying to get to the stacker (you find it in the metal guides that lift up), I would look at the metal plates to see if their bent.There has to be a gap to allow paper to feed down to the stacker and many times that top plate will get bent and block the paper path. Usually I resolve by reforming metal plate (bend upwards near their mounting point). High tech cure.
If the paper makes it to the stacker and just sits there (finishes first side, fails to start second side), there is a spring clutch in the back of the duplex that likes to fail which will cause this. Clutch failure results in tray being unable to lift the stack to the feed rollers, so no feed. Pull duplex out and look at spring clutch in big white cam assy.
Anything else would be rare and you'll have to give more info on where and how it's jamming.Comment
