3500C with CEC0 error
  • emujo
    • Jun 2009
    • 3009
    Roughly 140K copies, latest firmware..I have replaced registration motor (entire assembly with all gears), sensor, torque limiter with no success. Copier will run fine for 7-10 days, then CEC0 pops back up again. Not looking foward to LGC bd replacement yet, any body had this problem with a resolution? Emujo
  • toshibadale
    • Apr 2007
    • 117
    The only time I had this problem, I replaced the silver roller and all the springs and bushings that are on the door below the 2nd transfer. They had got into a bind and were not releasing properly.
    • ToshibaTech
      • Apr 2007
      • 580
      Kind of redundant looking at what you said but the only times I have had this problem I have sanded the shaft and cleaned the one way on the registration drive. (Can't remember exactly what shaft the one way is on but I remember it was obvious.) I have also seen customers some how break the transfer belt / 2nd transfer roller mating coupler. Not a good description... it's the black plastic thing on the transfer belt unit which has the wiring for the connector routed through it. The bearings on the 2transfer roller mate up to it.
      I will not give you service manuals or firmware.
      • emujo
        • Jun 2009
        • 3009
        It looks like Toshiba has acknowledged this a problem, but I don't have full access to the FYI site any longer. The oneway clutch has been re-designed. I'm ordering and will post the resolution when finished. EMujo
        • excanonguy
          • Jun 2008
          • 173
          I know this is an old thread but did the one-way clutch fix the issue? I have a 2330 with about 80k on it doing this now...
          • bauer
            • 72
            TT 09-112 e4520c error code CECO
            CONTENT
            We would like to inform you of the countermeasure to the "CEC0 error" caused by the locking problem of the one-way clutch in the drive unit.
            1. Investigation of the cause
            Follow the procedure below to check if the "CEC0 error" is caused by the locking problem of the one-way clutch, and if it is so, perform step 2 "Countermeasure".
            Note:
            The "CEC0 error" caused by the locking problem of the one-way clutch does not always materialize while the cause is actually being investigated. Therefore, even if problems other than locking do not occur, perform step 2 "Countermeasure".
            Procedure:
            (1) Take off the inner cover and the duct.
            (2) Perform the output check (03-239) if the edge of the shaft is rotated by 180 degrees and then stopped, pressing the [START] button each time.
            If it is not rotated, proceed to step (3) because the registration motor may not be rotating or the locking of the one-way clutch is defective.
            If it is rotated by 180 degrees and then not stopped, the 2nd transfer roller position detection sensor or the harness may be the cause.
            • emujo
              • Jun 2009
              • 3009
              Yes, the new clutch solved the issue. Emujo
              • digicor
                • Jul 2008
                • 1159
                Re: 3500C with CEC0 error
                i have this issue on a 281c, where is this one bearing located? i have parts man and cant find the part description, is it under the second transfer or accually in the machine in the back?thanks
                • bauer
                  • 72
                  The 3500C is not the same machine as the 281C
                  Transfer belt position detection abnormality (normal
                  speed): The home position of the transfer belt can-
                  not be detected. Clean sensors in the thransfer unit
                  • digicor
                    • Jul 2008
                    • 1159
                    ok thank you
                    • Alex1
                      • Oct 2012
                      • 285
                      Can anyone tell me where the Clutch is located please??
