not save settings Toshiba e-studio 4520c
  • grafix
    • Mar 2010
    • 18
    Will not save settings in the admin menu ... after the restart MFU reset to default settings (((How to solve the problem?
  • sdrawkcab
    Confused & Bewildered
    • Jun 2009
    • 317
    What settings are you refering too? if it's the Network settings, are you pressing 'Apply Now' when finished.
    Some days, it's just not worth chewing through the restraints
    • grafix
      • Mar 2010
      • 18
      Scanner&copy will not save settings. Аnd choice of language menu ...
      Is reset to default settings after a reboot...( 200dpi and color settings default)
      Colors is not natural ... When printing color dark. (White paper 80g/m), small white dots on the printed image.
      • grafix
        • Mar 2010
        • 18
        Eurica!!! Found a solution so simple...
        • tinnyjay
          • Oct 2009
          • 663
          Does it has installed a Network Based Print Controller?
          If yes,go to Top Access and change General Copy Settings(Scan setting,resolution,Energy Saver and other things...)
          If you want to change language go to Menu and and see if English is installed.If it is,turn the copier off and enter service mode turning on by pressing 0+8 and 220-0-Interrupt or Enter and wait for "reboot the machine".
          If you have problem with printing density,sharpness,gamma i sugest you to do nothing by yourself,but find a good techician and let the "stress" to him.
          "Who loves the roses,must also bear thumbs"
          • TheOwl
            • Nov 2008
            • 1732
            What was the solution?
            • grafix
              • Mar 2010
              • 18
              Reply to e2820c_3520c_4520c_MFP_Management_Guide_Ver04.pdf, e2820c_3520c_4520c_Printing_Guide_Ver02.pdf, e2820c_3520c_4520c_Scanning_Guide_Ver03.pdf, e2820c_3520c_4520c_Imaging_Manual_Ver01.pdf... tech doc
              • grafix
                • Mar 2010
                • 18
                Toshiba UserManuals hxxp://www.gioffice.com/Op_manuals.htm
