eStudio 280 Can't Access TOP ACCESS via network
  • mrfuser
    • 1622
    Anyone know why we would not be able to access the "top access" of the eStudio 280? Machine works perfect. I don't know of a setting in admin that would stop this. Any ideas?
    Kelly
  • ToshibaTech
    • Apr 2007
    • 580
    Make sure HTTP is enabled under Admin>Network. Also make sure you are not behind a proxy which might be blocking it. To really make sure nothing in between is blocking it connect directly to the machine and test it.
    I will not give you service manuals or firmware.
    • mrfuser
      • 1622
      top access
      I connected directly with crossover and can't get into top access via IP. I set up scan to box and installed downloader to go fetch docs. Works, but would still be nice to get into web access for setting up scan to email. Prints fine also.
      Kelly
      • ivovb
        • 695
        Check in 08 if something concerning http port is changed. Default is 8080...
        BR
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • Mr Spock
          Vulcan Inventor of Death
          • Aug 2006
          • 2064
          Check the above about the http and a firmware reload are all that come to mind.
          • ToshibaTech
            • Apr 2007
            • 580
            Oh also try 08-690, and 08-947 at the same time. Warning: 690 formats your HDD so it'll get rid of scanned documents, templates, fax recv foward, address book.... so you might try 947 by itself first. 947 "initializes the firmware" but it also rebuilds the top access website.
            • tinnyjay
              • Oct 2009
              • 663
              On the copier panel go to :
              User Function-Admin-Network-Http.
              Check if it is enabled and check ports.
              One port must be 80 and other port must be 8080.
              "Who loves the roses,must also bear thumbs"
              • jamesyboy
                toner monkey
                • Jul 2010
                • 188
                you have probally tried this but can you get top access directly using a laptop and crossover cable ie connecting straght into the mfp and eliminating the network which may have restictions ie intranet not internet
