Toshiba estudio 550 shuts off
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Copier shuts off only a few seconds after you turn the power on.
  • Travis06
    Tech.
    • 193
    Probably a blown thermo fuse and/or fuse holder in the fuser unit, don't forget to reset 08 400.
    I have also had a blown IH board do this.
    • blazebusiness
      • 1257
      Yea .. I was thinking fuser also but no time to enter service mode to reset codes and no code comes up when machine shuts off breaker so quickly. Any suggestions? Would door open help?
      • emujo
        • Jun 2009
        • 3009
        In this case, you need to leave front door open when restting code..08/400. After code is reset, re-apply power with door still open. If power remains on until you shut the door, then you probably have a blown IH board and/or IH coil. If power trips before door shuts, then poblem lies elsewhere.. power supply maybe. You'de have to look at the timing charts to figure out the sequence of events. Sometimes you have to pull connectors from the LGC bd 1 by 1 to isolate the componant that has gone bad..ie developer motor or fuser drive motor. Emujo
        • blazebusiness
          • 1257
          That exactly the push in the right direction that I needed. Much appreciated. Giving you rep power for your effort.
          • blazebusiness
            • 1257
            Ok more info now-------met with one of my guys and he replaced the fuser rollers a week ago. Unit worked fine for a couple of days & then began to shut down infrequently. This became worse until the power began shutting off after a couple seconds (our current problem) . Just dissassembled unit & fuses , thermistors , etc.. test ok. If door is open the power does not shut off coupled with the fact that my guy had just worked on the fuser so our trouble is in that area of the machine. IH board (part# ?) or IH coil (part#6LA05236000) looking more like the source of the trouble.
            • emujo
              • Jun 2009
              • 3009
              Some other causes since you mention fuser was just worked on...Paper dust in fuser/frame side connectors causing thermistors to mis read. Lower thermistor is being pinched by rear cover of fuser (covers drive gears). LFR is not riding correctly in the bearing holders causing uneven heating. Incorrect screws (too long) used to secure IH coil harness cables and they are digging into PWB. 16 pin connector on IH board not fully seated (pulls out when cover is pushed too far down. All connectors are color coded, but not tech proof..re-check all 5. If you can find another fuser to test with, at least you can rule out LGC bd issue. Some times, the error code can point you in the right direction. Follow SM for discription of what each sub-code means. Thanks for rep power. Emujo
              • blazebusiness
                • 1257
                My pleasure...thanks for responding in such detail. Will check all those items.
                • ivovb
                  • 695
                  Also check/change main power switch. Do You have external LCF connected? If Yes disconnect and check if it the problem. Do the same with the rest of the options if there are some. Check cables to HDD especially power one.
                  BR
                  I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
                  • blazebusiness
                    • 1257
                    thanks....will do.
                    • blazebusiness
                      • 1257
                      my guy reset a fuser error & inspected fuser.....if problem does not reoccur I guess its solved for now----------thanks to all who replied.
                      • Oystercopy
                        • Oct 2009
                        • 623
                        Every single time I have had this happen, its been one of the THERMAL FUSES. When I've ohmed them out, one of them is dead. Very common on this box.
                        • blazebusiness
                          • 1257
                          They actually ohmed out good on this occasion.
                          • Oystercopy
                            • Oct 2009
                            • 623
                            Then the other guess would be a dead short in the Heater Coil, but that's pretty unusual. The white plastic sleeve around the heater coil may have worn away and letting it arc to the roller. The sleeve is available separately to replace, if you find you need to replace it.
                            • jamesyboy
                              toner monkey
                              • Jul 2010
                              • 188
                              Just a thought I have seen some strange fuser problems that turned out to be caused by holes in the sleeve of the induction coil also check harness from bottom of ih board that runs below fuser unit to lwr male connector that can work out as the ih board is lowerd to remove fuser good luck
