Toshiba 1710 registration & lead edge void
    • 22743
    This should be an easy one for you toshiba guys. I'm working on a 1710 with no lead edge void & registration leads the copy by 2mm. How do I adjust the registration & lead edge void. I figured out the, hold 05 while powering up to get to the adjustment mode. What next?
  • dbrownlee
    • Sep 2005
    • 198
    Registration is 05-53. Range 00-15, 8 is default. M0ves 1/2 mm per step. Interrupt to save, 34 together to test copy. 05-56 is byp reg, same range.05-27 is L.E. void, range 00-15, default is 8. Same setting/test procedure as above. Hope that helps, Dave.
    GO TIGERS!!
      • 22743
      Thanks! I won't see this machine for ~10 days (I'm in school). I'll try it when I get back.
        • 22743
        Thanks, dbrownlee!
        Worked like a charm!
