What is Toshiba End of life meter E studio Series 550 600 etc.
  • Electrictoner
    • 48
    [Misc] What is Toshiba End of life meter E studio Series 550 600 etc.
    I don't usually work on these Machines but a couple of techs told me after 1 million clicks Forget about em. Reason asking
    I have opportunity to get 4 at a cheap price with about 1..2 mil on them. Is there something in particular that goes after 1 mil that costs $$$ or is just a marketing ploy for cust. to buy newer machines? Are parts cost comparable to Canon IR or Konica BW machines?
    Billy
  • jamesyboy
    toner monkey
    • Jul 2010
    • 188
    What models you looking at tosh is as good as any and very easy to work on
    • jamesyboy
      toner monkey
      • Jul 2010
      • 188
      sorry just woke up and seen models 550 etc these are good work horses Ive got some that have done 5 million plus devunit gives up if you dont keep an eye on it pm 500k and as long as you do it happy days you can get a lot more out of the fuser exspensive to refurb if they have not been looked after
      • ivovb
        • 695
        Billy
        These are two different families. Older one eSt550/650/810 has a problems with dev unit, laser unit, controller's hdd. Newer and better one is eSt520/600/720/850 - has a problems with dev unit (get all of the gears in any case), keep hdd in car, find latest firmware, provide separate power outlet with serge protector. In both series check fuser each 100-200 k copies and set latest mods.
        BR
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • Travis06
          Tech.
          • 193
          The 550/650/810's turn into a headache if not properly maintained. I have had good luck in schools up to the 4-5 million count mark. The CCD's and PSU's start popping and ALL drive gears/harness's have been replaced.
          The 520/600/720/850 series are starting to end the five year lease's and I have a few with close to 10 million. The 720/850 for some reason seam to run better over the long run.
          • Mr Spock
            Vulcan Inventor of Death
            • Aug 2006
            • 2064
            Trivial question. What is the difference between the 850 fuser and the 520/600/720 fuser?
            After checking every part number the only difference is the tension springs.
            I have 3 720 with over 2 million and run 200-300k between service calls (usually upper fuser roller) and only 2 550's and both have 3 million and very low service calls (usually the gl1010 related or fuser rollers). The key is the service history if they have been maintained by a good tech then they can go much longer then 1-2 million. If they have not then plan on spending a good deal of money on them until they are back to spec.
            • Electrictoner
              • 48
              Don't have that log history and since Tosh are not my usual cup of tea as they say I think i will pass these up
              Billy
              • ivovb
                • 695
                Yep it sounds strange. Moreover - procedure for adjusting the fuser is the same for 520/600/720 and 850.
                • Oystercopy
                  • Oct 2009
                  • 623
                  That's funny... I used the put the newer style RED Fuser Springs from the 520/600 into the older style 550 when I rebuilt the Fusers. Since Toshiba has historically been WEAK when it comes to fuser pressure, this seemed to help the lousy 550 series get a FEW more clicks before failure. Those boxes were TERRIBLE about early developer failure and the fusers would "scum" really badly. The improvement they made - which I assume is in the Toner/Developer formulation - had a HUGE impact on the newer boxes. They were even able to completely remove the Fuser Cleaning Rollers as a result. I always wondered why they couldn't have offered a mod to convert the older boxes to the newer, but they must have determined it "not cost-effective".
                  • tinnyjay
                    • Oct 2009
                    • 663
                    After a lot of consumables services,you will have problems with LGC,PCB,SYS boards,developer unit,fuser unit and power suply.
                    I think normally even these parts could have a long life,Toshiba stop them,by a copy-counting stopable program.
                    And the maximum cannot goes up to 5.000.000- 6.000.000 copies.(My Canon IR105+ has a maximum of 16.000.000 copies and still now has just only 1.084.000 copies).
                    THIS IS ONLY WHAT I THINK!
                    "Who loves the roses,must also bear thumbs"
                    • ivovb
                      • 695
                      Unfortunately there are a lot of such not logical things branded like this.
                      BR
                      • Electrictoner
                        • 48
                        16,000,000 Were you get this info never seen in Canon document if you have such would like to see it very interesting!!!
                        limits on 7105s too???
                        • mhmsaqer
                          field Supervisor
                          • Jun 2007
                          • 83
                          The Rio Grande series (I've the 600 and th 850) is an excellent built machine, we used to have very few service call between PM's most of them are related to the upper Fuser roller and transfer unit junction harness.
                          other than this we don't have any serious issue,we've smthn like 20 machine with counter around 1 to 3 Million copies.
                          the evidence of this is that Toshiba has did exactly nothing in it's new series the Alabama 555,655,855 machines except the panel and user interface.
                          P.S.
                          Up to Toshiba SHB the maximum life for this machine is 12 Million
                          BR,
                          Mohammed
                          Be happy for a moment - this moment is your life.
                          Omar Khayyam
