Tosh ES 450 eb 50 code?
  • Hansen88
    • 1069
    Hello I was wondering if anyone has run into this code and has a fix for it? I do have the manuals but like usual everything checks out but still have problem. Thanks for any help.
  • jamesyboy
    toner monkey
    • Jul 2010
    • 188
    [EB50] Paper left on the transport path due to multiple feeding
    p feed problem try changing feed stations over
    change feed tyres!
    • emujo
      • Jun 2009
      • 3009
      Assuming you have feed tires and clutches in good shape, more than likely you have dust/dirt build up in sensors that detect paper travling through the verticle paper path. Disassemble and clean the sensors, check the condition of the actuator flags (nicks/flattened spots) and replace as necessary. The bridge unit sensors can also give you EB50 codes if they are filthy.
      • Hansen88
        • 1069
        Thanks for the replys. I went there myself to look at the problem and found a paper scrap on a bridge unit actuater and that was the problem. It also had a main motor error code that was from the fuser bearings being locked up.
        • ToshibaTech
          • Apr 2007
          • 580
          That's the first bearings I've ever heard of locking up on Toshibas... are we just lucky?
          I will not give you service manuals or firmware.
