eStudio 2830c File overwrite issue
  • Systech
    • 16
    [Misc] eStudio 2830c File overwrite issue
    Is there way when scanning to FTP to have the copier overwrite a file, if that file already exist? Right now if the file exist the scanner adds -001 to end of the name. We need to have overwrite the file with the name entered by the user.
  • emujo
    • Jun 2009
    • 3009
    Don't work on this version of the Toshibas, but on the older systems, when you scan (either FTP, email, or SMB) and leave the document name the default value, the MFP must put something on the end of the file name to allow the end user to determine which doc they want. So if you scan a doc today at 11am and leave the default name alone you get a doc named "DOC092910.pdf". Any other jobs you scan on that date are going to be DOC092910-001,002,003 etc. If you want anything else you must teach the users to modify the document name prior to scanning the job. This can be done by touching edit within the scan screen. Emujo
    • Systech
      • 16
      Our users are trained how to name the file. The problem exist when they name the file 123456.pdf, then later that file needs to be updated, do to changes in the document(123456.pdf). So they scan the updated file, naming it 123456.pdf, the scanner then saves the file 123456-001.pdf. We cannot have the -001 at the end. If this is the way it works, we will sending this back, as it's not something we can work around.
      • emujo
        • Jun 2009
        • 3009
        Now I see the issue...I tried this on one of our KonicaMinolta products..scanned as 123456.pdf. Printed and scanned again as 123456.pdf and now I have 2 different docs with the name as 123456.pdf. No"-001,002 etc. I would suggest calling your Toshiba rep and have him/her get Toshiba support on line and ask if this can work. If not, I can always send a KM rep your way to upgrade. PM me if I can assist. Emujo
        • Systech
          • 16
          Funny thing you mentioned KM. That is what this product just replaced.
          I'll let you what I find out from Toshiba Rep.
            • 8201
            You should first update your copier firmware. V216 came out in late Aug with lots of upgrades. Minor V218 in Sept.
            There are two ways to scan. Both must be set up from the Top Access Web Brower.
            Admin, Save as File, Format, File Name Format, select from Drop Down box.
            If Scanning from a Template, select the Grey Grey Registration Tab.
            Create your Template, Edit, Save as File Setting, File Name
            • Systech
              • 16
              Not sure how to check the version (but they just did an update yesterday-hopefully they put the latest on).
              I have the templates setup. There is no selection for making user enter filename (which I understand). However, renaming the file to 123456-001.pdf is not an option for us.
                • 8201
                Go to web browser and type in IP address of copier.
                Up will pop Toshiba Top Access.
                Press Admin. Default password is 123456
                Version Tab. What are the last three digits of Copier Firmware Version.
                • Systech
                  • 16
                  Copier Firmware Version--T450SY0U218
                  Copier Main ROM Version--450M-21
                  Copier Scanner ROM Version--450S-10
                    • 8201
                    Perhaps, I am misreading your question.
                    You can rename files "on the fly" from a Template.
                    Press Template.
                    Press File/ USB
                    Press File Name. Keyboard in. Press OK.
                    Press Scan.
                    You can check. Press Job Status on LCD display. Press Log. Press Scan.
                      • 8201
                      Your local techs have upgraded your copier to latest version.
                      • Systech
                        • 16
                        OK I'll try and lay this out better.
                        I have scanned a document to a network share. File name is 123456.pdf (I manually named this file). There are changes made to the original 123456.pdf (hand written changes on the pdf). The file 123456.pdf needs to be re-scanned to the same location with the exact same name. However the copier is adding -001 to the end of the file name. I can't use the -001 as our application doesn't look for this. It looks for 123456.pdf, not 123456-001.pdf.
                          • 8201
                          I have the same copier in my office and have just tried the same.
                          I get the same result as you.
                          If you use the same file name on the same day the copier will auto add -001.
                          I have called Toshiba Tech support and cannot find a way to turn this off.
                          Your users will have to slightly rename the file the second time it is scanned.
                          • Systech
                            • 16
                            OK, well then my option is to return this copier. This simply will not work in our environment.
                              • 8201
                              If the copier is a Lease and you have made your first payment, the transaction is funded by the Leasing company. There is likely no way out except for a very expensive Balance of payments.
                              If your copier is a Purchase and you have made your payment and you have made more than 1k clicks, you now have a used copier to trade in.
