I don't know what's going on in the field with these things, but I'm having a HECK of a problem with all kinds of copy quality issues.... I've been using OEM Drums for a while, but it seems like the drums are failing prematurely lately. I'm getting overall dark, shadowy and streaky copies. I've also got (what appears to be offsetting) but the Fuser is not at fault; problem happens BEFORE fuser.
I suspected drum ground, and have now checked several machines to see if I'm getting drum ground from the machine frame DIRECTLY to the flange on the end of the drum and NO GROUND... I'm wondering how it is that these drums achieve ground because they don't have a ground clip inside the drum (the way that the Katun equivalent and most other drums do....). I'm told that the rear flange on the OEM Drum is of a conductive material, but I have no clue.
WEIRD.... I guess I could also be looking at failed discharge/LED erase lamps and the like, but it seems so random, and I'm having this trouble on (about) 4 machines now.
Somebody tell me I'm not crazy, PLEASE??
OC
OC
