estudio 230 C970
  • mrfuser
    • 1622
    estudio 230 C970
    Okay, new drum, blade, developer, fuser, etc.
    Machine goes into a C970. Charge corona looks just fine, it is the sawtooth type of corona with a grid. Drum will go completely black with toner when try to run a copy so obviously something is wrong with charge, but what?
    Ever seen this?
    Kelly
  • bojans
    • 1313
    Did you check transfer corona?
    I had same problems when transfer corona wire got broken.
    • mrfuser
      • 1622
      No broken wires. Would not this cause NO TONER on drum?
      • Travis06
        Tech.
        • 193
        cut three turns off m/c spring. If so, need new spring. Happened a ton on e450 series, (along with multiple mods also)
        • mrfuser
          • 1622
          okay, but spring is pulling the sawtooth corona, not a standard wire. Would this make a difference? Also when we go into service mode and do an 03-252 to turn on the corona it immediately pops the C970 code. Sounds like a buzzing from inside, must be a short somewhere in there, just having a lot of fun trying to find out what it is arcing on!
          Any tips are appreciated!
          Kelly
          • Travis06
            Tech.
            • 193
            yes, happened to me on the 230 series a few times. Also check on the machine where the m/c goes into, I have had that fall apart.
            • mrfuser
              • 1622
              The connector at the rear of the machine was out of place. What a job to get to it! Sheesh, could Toshiba bury it any deeper?
              Kelly
              • digivision
                • Aug 2009
                • 44
                Hi Fnd,
                remove the Main Corona unit Cleaner ( Green colour Plastic stick)..........&
                ...............ur error will be canceled.
                BR
                • tinnyjay
                  • Oct 2009
                  • 663
                  Check the corona's spring?
                  Is it in its place?
                  "Who loves the roses,must also bear thumbs"
                  • onlineprofitinternetshop
                    • 17
                    Re: estudio 230 C970
                    Check this error C970 today in my EStudio 230.., just searching the correct answer to my problem. How this problem solved. I check some of the parts that connected to C970 error.,
                    • Harry
                      • 228
                      please take out the green corona cleaning assy there was a little plastic mylar to clean the saw corona this short primary corona so put this Whole shit appart. the mf works fine without this thing.
                      good luck harry
                      • mrfuser
                        • 1622
                        Read this ancient thread and they answer will come to you
                          • 17
                          I got this trouble few months ago.., Check the side cover if there is broken or parts from it.., the two important parts for this trouble C970 are rear main charge corona terminal if broken and the side cover can take this trouble.
