e-Studio 850 E-010 -Fuser not runing
  • ToshibaBHM
    • Jun 2025
    Hi all,
    I've collected this 850 from my client, in working condition & I only wanted to make some copies on it now (+- after a month or so) & it gives me E-010 paper jams. The fuser is not turning. I've tried to run it in test mode 03-113 with no luck.
    There are no blown fuses on the power supply & no pinched harness / wires & all connectors are securely in place.
    Any help will be appreciated.
    Jacques
  • Gregg
    Is the drive gear stripped?
    • ToshibaTech
      • Apr 2007
      • 580
      I agree the drive units on the older ones were a problem and especially the little idle gear on the fuser with the one-way on it.
      I will not give you service manuals or firmware.
      • ToshibaBHM
        Hi & thanx for the reply. No the gear is not broken. I've tried to run the motor on an 810 & I blew the driver IC. OOPS-there;s that famous japanese smoke!
        Will try to find another motor & try again.
        Any other suggestions?
        J
        • Centerman
          Old School New skool
          • 5
          You're on the right track with the Fuser Drive Motor. If there are no stripped gears and you can't run it in test mode, it's dead.
