e-studio 6520c C449
  • Mark B
    • Jul 2006
    • 153
    e-studio 6520c C449
    I have an e-studio 6520c with a c449 code. I have replaced the LSU board the thermistors and the thermopiles still no change. The machine comes to ready, I can make 20 copies then the code comes. Any ideas?
  • JustManuals
    • Jan 2006
    • 9818
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • Travis06
      Tech.
      • 193
      Did you check to make sure the lamps in the the p/r are coming on?
      • Mark B
        • Jul 2006
        • 153
        What do you mean by the p/r? I do not work on toshibas, just Kyoceras. That is where the problem lies. Kyocera bought these e-studio 6520's and put there own front panel on it and calls them a 650C. the support that I am getting from kyocera is very bad because no one is use to the product.
        What is strange is that the machine comes to ready makes 10 to 20 copies then gives a C449. the code can be reset in 08 mode.
        • Travis06
          Tech.
          • 193
          Pressure Roller. Seams like it is losing heat when the paper is passing through the fuser.
          • ToshibaTech
            • Apr 2007
            • 580
            Is the machine plugged into a 20A circuit? These things have a max load of 18A and need their own circuit breaker...
            I will not give you service manuals or firmware.
            • Mark B
              • Jul 2006
              • 153
              The c449 is an overheat code. That is what is weird that the machine comes to ready and making copies caauses the overheat condition. Yes it is on a 20 amp circuit. I actually pulled the machine and now it is in the shop. I orered a new fuser for it, I will post the results
              • Mark B
                • Jul 2006
                • 153
                The new fuser fixed it. It looks like it will be covered under warranty, but I still would have liked to know exactly what was wrong with it.
