Hello
I will have to start of by saying that Im probarbly a newbie compared to most of you in here.
So I have big hopes for getting help with my problem.
I have recently bought an estudio-281c. I works nicely when it comes to papperhandling and so on. But when I print the pictures becomes faded and greyish. Not evenly but like the color have not gotten stuck to the paper. The problem appears on all of the colors. I have changed toners so that's not it. I have tried diffrent pappers. It's kind of hard to explain exactly how it looks. If I make a test print the collors comes out nice and smoth.
I did a check in the system and there are not really any components that are in need of changing other than,
main charger wire
wire cleaning pad
2nd transfer roller.
fuser press roller finger
fuser pressroller eraser brush
What I found when doing an test is that the main motor checked in as abnormal but i have not gotten any problem with color deviation.
Im pretty lost here and dont know what to change to make the pictures become smoth and clear. Every now and then the pictures comes out better and almost perfect.
thank you in advance.
All the best
Fredrik
main charger wire
wire cleaning pad
All the best
Fredrik
