Toshiba Estudio 351C Copy and Print Quality
  • jcontractor
    • Aug 2010
    • 247
    [Misc] Toshiba Estudio 351C Copy and Print Quality
    Hi,
    Attached is a Scanned printout from a Toshiba Estudio 351C, It do the same in print and Copy. Second transfer roller was changed.
    I'm doing some other cleaning procedures, but I think that will be like a standard cleaning. This failure could be another thing.
    Any suggestions or comments will be really appreciated.
    Thanks to all.
  • tinnyjay
    • Oct 2009
    • 666
    Originally posted by jcontractor
    Hi,
    Thanks to all.
    Check transfer belt.
    "Who loves the roses,must also bear thumbs"
    • jcontractor
      • Aug 2010
      • 247
      I just disassemble all unit minutes ago, First Transfer Roller was in very good condition, I clean up al toner residues and the transfer belt was in a good conditions too. I will let you know as soon I test the machine today.
      • jcontractor
        • Aug 2010
        • 247
        Everything was cleaned, transfer belt was in a good condition, what do you recommend?
        • tinnyjay
          • Oct 2009
          • 666
          Still the same?
          Is it print or copy?
          Try a 05-200 and make user calibration.
          • jcontractor
            • Aug 2010
            • 247
            OK, I'm just in the front of the machine right now.
            • tinnyjay
              • Oct 2009
              • 666
              Still the same?
              • jcontractor
                • Aug 2010
                • 247
                Both now is worst.
                • jcontractor
                  • Aug 2010
                  • 247
                  I clean the Transfer components and now I have a problem with cleaning blade of the transfer belt, I have color lines in my prints and copies.
                  • tinnyjay
                    • Oct 2009
                    • 666
                    Both now is worst.
                    Did u make a calibration to check printout color blocks?
                    • tinnyjay
                      • Oct 2009
                      • 666
                      This is a mechanical problem.
                      Check the plastic plate of Drum Cleaning Blade mechanism.
                      Is it straight,or curved.
                      It can touch transfer belt.
                      Check it out.
                      • jcontractor
                        • Aug 2010
                        • 247
                        OK. I run the color blocks calibrations.
                        It is getting a little bit more clear.
                        • tinnyjay
                          • Oct 2009
                          • 666
                          Try 05-200 and wait till it finishes.After that,try calibration.
                          • jcontractor
                            • Aug 2010
                            • 247
                            I will change the cleaning blades, I let you know later on the week.
