Remove paper from finisher
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1875
    I have an ES452 with an MJ1101 that shows "remove paper from the finisher" when trying to output to the staple tray. I searched FYI, but didn't find anything. Can't find anywhere to check the sensors. Any ideas appreciated.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
  • tmaged
    • Oct 2008
    • 1875
    Nobody ?
    Hope that helps !
    -Tony
    www.dtios.com
    • tinnyjay
      • Oct 2009
      • 663
      Check the sensor on the tray.
      "Who loves the roses,must also bear thumbs"
      • CT Copier Repair
        • Mar 2010
        • 304
        IS there paper in the tray? In the finisher?
        go into service mode and start checking sensor states change them and look for the corresponding state change
        Brian
        • tmaged
          • Oct 2008
          • 1875
          That's the problem, there doesn't seem to be a check for those sensors. Tried switching it with the other tray sensor and that didn't change anything. Must be the board not changing signals ?
          Hope that helps !
          -Tony
          www.dtios.com
          • Mr Spock
            Vulcan Inventor of Death
            • Aug 2006
            • 2064
            Find the finisher manual on FYI. I believe you have to use the dipswitches on the finisher pwb to test the switches. Also check the actuator on the tray for easy operation.
            • tmaged
              • Oct 2008
              • 1875
              I forgot the goofy way Toshiba does crap. Yep, it's in the Finisher manual. I did find a troubleshooting guide for that finisher also on FYI. Thanks !
              Hope that helps !
              -Tony
              www.dtios.com
              • tmaged
                • Oct 2008
                • 1875
                I'm so glad we're no longer a Toshiba dealer. The service manual is incorrect as far as checking the sensors. It tells you to change dipswitch 3, but it's really two. After figuring that out, I never could get in to test the sensor. It says 5-4, but that's not correct either. We've got a 1024 in the warehouse luckily.
                Hope that helps !
                -Tony
                www.dtios.com
                • arnh79
                  • 468
                  We've had this problem before. It was a cracked wire harness- which the MJ1101's are famous for.
                  Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
                  • tmaged
                    • Oct 2008
                    • 1875
                    Thanks for the help. It's definitely worth ordering one to try.
                    Hope that helps !
                    -Tony
                    www.dtios.com
