Toshiba E-520 fuser drive gear replacement?
  • Buddy
    • Aug 2009
    • 285
    The gear in my customer's maching went bad. (Its the one that the fuser motor drives.) Has anyone done this job. It looks like a bear. Any tips. Thanks and happy 4th!!
  • JustManuals
    • Jan 2006
    • 9838
    Re: Toshiba E-520 fuser drive gear replacement?
    Paul@justmanuals.com
    • Buddy
      • Aug 2009
      • 285
      Go F yourself spam douche!
      • Travis06
        Tech.
        • 193
        Done it about 100+ times. Remove the back cover. Don't let all the wires fool you. Take out the 4 or sometimes 5 screws that hold the entire fuser drive in. Take out the 2 screws that hold the fan/filter unit(big black one) above the drive. Lift up on drive unit and lean the top of it toward you. Take e-clip off and old gear (sometimes a little stuck). Clean shaft add a little lube and put new gear and clip back on. Now here is the only tricky part. Put the drive back in making sure you get the bottom 2 feet back in the frame.(if they are not in, your duplex unit will not drive). Screw back in and put fan unit back in. Should take about 5 to 10 minutes. Some people don't take the fan unit out, but for me it gives me enough clearance to never have to unplug a fuser cable.
        • Buddy
          • Aug 2009
          • 285
          You da man, Travis. Much appreciated!
