Toshiba e-studio 555 error code f111
  • Hemant Pillay
    • Sep 2025
    [Error Code] Toshiba e-studio 555 error code f111
    During the installation of the new toshiba copier machine es 555 i comfronted with a unique problem,when i make the copy from the expourse glass its ok,but when i use adf to copy,the expourse lamp the on full time an dthe machine is running,after few minutes it gives out a blanket copy and issues error code f111,the problem is in the connector of the adf unit,i found that the adf connector at the back has a loose connection,one of the pin from the connector has pop out of position,try fitting it properly to fix the problem.......
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    Re: Toshiba e-studio 555 error code f111
    I dont quite understand this thread. Did you fix the fault?
    It didn't say that I couldn't do it in the manual.
    • Hemant Pillay
      ya its being fixed js the loose conection
