E-Bridge X service codes
  • arnh79
    • 468
    All the manuals I have for EBX machines are missing the list of 03,04,05,08 codes. There is a section in the manual for each series of codes, but it only tells you how to input them, not what they are. We were sent a couple of spread sheets that tell you the equivalent codes in the new 4 digit format, but its awkward to use. I was under the impression that a f/w version was going to come out that would make the service modes into an on-screen format- similar to Samsung and Konica Minolta. But now we just heard that the latest f/w isn't going to do that. So my question is: Has anyone seen an offical published list of service codes in a manual for the EBX series? Or does anyone know if they plan to move to an on-screen style?
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
  • fourl6
    • Nov 2008
    • 94
    Re: E-Bridge X service codes
    They are now in the Service Manuals not the Service Handbooks
    Hope that helps
    I know as much as you re the on screen menu...
    Cam
    • michaelc
      Field Tech
      • Mar 2011
      • 590
      Just got back from the update course today. We got the codes for the machines. You dont need to use the 'classic' way to input codes. There is a new way being introduced. Its really good.
      It didn't say that I couldn't do it in the manual.
      • fourl6
        • Nov 2008
        • 94
        This sounds great, we just got sent some new firmware sent to us (V2000) for the es2040c series without any release notes yet, we havent got any ebX machines in the showroom to have a look atm,
        im guessing its in this firmware, how do you get to it?
        Cheers Cam
        • michaelc
          Field Tech
          • Mar 2011
          • 590
          Yeah, with the v2000 you can access most codes via the new way apart from the 0+3 codes. The spread sheets with the equivalent codes is handy.
          When updating the firmware, do option 4 first (sys). Then the rest after. That was the tip I was given and I have updated some on the course and 1 in our workshop so far with no probs.
            • 8144
            Ver 2000 firmware is applied with Aug. production.
            For earlier e2040c series copiers when updating to V2000, you must also use the new V2.10 CD with the latest Drivers.
            So it will be a pain to update machines in the field atttached to multiple PCs, as you must remove all Drivers/ Addressbook Viewer/TWAIN Driver, etc before you can add new drivers.
            Also note the firmware you use is different from e2040c/e2540c/e3040c and e3540c/e4540c.
            • michaelc
              Field Tech
              • Mar 2011
              • 590
              Yeah, High and low for the ADF firmware.
              • fourl6
                • Nov 2008
                • 94
                Hey guys, iv just Updated a es4540c to firmware V2000, to access Service UI it the manual says
                1 "press the user functions button"
                2 "enter the password for the service UI on the user function screen"
                i cant find anywhere what the password for service UI is?
                Cheers Cam
                • fourl6
                  • Nov 2008
                  • 94
                  Apparently theres a bulletin coming in a few days
                  • michaelc
                    Field Tech
                    • Mar 2011
                    • 590
                    The password is blank. Just hit enter No 03 mode in there yet tho
                    • NSD
                      • Aug 2011
                      • 44
                      If you have the spearsheet the best way to use it is to use Excel filters. that way you can filter for the old code and it just shows you the new code. easy than scrolling through the whole sheet.
                      How have people got on with the new universal drivers and the plugins? We have had some issues at customers sites but now have a couple of workarounds.
                      • venluckey
                        • Mar 2016
                        • 36
                        Was there a link to the spreadsheets? I work intermittently on these machines,and are always needing to google the Codes needed. Does someone have a cheat sheet of commonly used codes?
                        ~~Venluckey
                          • 22997
                          Not a lot of detail, but most of the time enough to get you to the right area. =^..^=
                          • venluckey
                            • Mar 2016
                            • 36
                            https://printcopy.info/?l=en&mod=erc
                            Thank you very Much.
