ADF Scanning half of image light and streaky?
  • stuee
    • Aug 2025
    Hi.
    I purchased my machine from ebay and it works fine apart from when i use the adf.
    When i place a document on the scan bed and photo copy it is perfectly fine, but when i put the same image through the ADF it print without error but half the image is faded and streaky.
    I have attached a file to show you the original and ADF copy.
    Anyone have a rough idea what is the problem or how to fix this?
    Im a little tech savvy so can carry out adjustments etc if directed.
    thanks
    Stuart
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    Re: ADF Scanning half of image light and streaky?
    What model is it you are using ?
    It didn't say that I couldn't do it in the manual.
    • stuee
      OOps, i forgot to mention.
      Its a Estudio 230 B&W.
      Thanks for replying too, i was wondering if anyone still used this forum.
      • lucky777
        • Oct 2007
        • 54
        We had some machines that did that late ya en the top of the frame got bent in shipping. Df wouldn't scan right since it could't sit flat on glass. Simply heave on the top of the frame and see if it helps. Ours were 255's.
        • remielee
          Technical Analyst
          • Mar 2010
          • 140
          Did you try to clean the mirros, remove the platen glass and clean all the mirros and the small rectangular glass beside the platen which the paper pass from adf and also the exposure lamp, hope it helps.
