toshiba 723 stuck on splash
  • jfiscaro
    [Misc] toshiba 723 stuck on splash
    replaced system board tried to update hdd and firmware , neither would take . machine is still stuck on splash screen . any ideas on a fix?
  • TheOwl
    • Nov 2008
    • 1732
    Re: toshiba 723 stuck on splash
    Did you clear the NVRAM flags and partition the HDD correctly all from assist mode?
    • jfiscaro
      thanks but yes i did all that and still having the same issue
      • mckinley
        Chief Twiddler
        • Dec 2006
        • 150
        Did you make sure to put the Nvram & ROMs off the old system board onto the new one?
        Is the board new or second hand? if it's not new, is it an older rom version than the one you removed? (had a similar issue on 4511s when fitting a S/H sys board & the rom version on the board was much lower than the one that came off & the MFD wouldn't boot)
        Is it the correct sys board (ie: not for another varient of the RIO)?
        Have you tried changine the HDD as this is probably the most common cause of an MFD not booting / hanging at the 'splash screen'.
        can you get into 05 or 08 mode? if you can, check the serial number is there.
        What was the initial fault? fairly unusual for a sys board to fail on these.
        Happiness Is The Road.
        • michaelc
          Field Tech
          • Mar 2011
          • 590
          Sounds like something to do with the system board. What was the original fault you changed the system board for?
          It didn't say that I couldn't do it in the manual.
          • JVC
            • Jun 2011
            • 151
            I've seen the same problem a few times. Did you reseat the nvram? A couple of times reseating it fixed and the others I had to replace it.
              • 8227
              Try forcing the firmware upgrade with DLM320 jig and latest EPROMS.
